Cvt problem? Only moves with a push.
Old May 25, 2017 | 06:30 PM
TJSwear's Avatar
Default Cvt problem? Only moves with a push.
I have a Kymco mongoose 90. Long story, but it sat in a warehouse for 8 years. Almost brand new. Replaced the carb and it ran better, but it will only move if I give it full throttle and push it. If I lift the rear end, it runs fine. Does anyone have any experience with this? Any suggestions would be appreciated.
Old May 25, 2017 | 06:37 PM
Sounds like you need to pull the clutch cover and clean/check out the belt and clutches.Sitting up 8 years,there could be corrosion on the clutches causing sticking or the belt could be cracked and need replacement also.
Old May 25, 2017 | 06:55 PM
LT80's Avatar
LT80 Expert
I've found mice to be the main culprit.
Old May 25, 2017 | 07:26 PM
TJSwear's Avatar
I just took the belt off. It looked good, but I wanted a second opinion, so I took it to the dealer. He thought it looked good. I took carb cleaner to the clutch. What should I look for on the clutches?
Old May 25, 2017 | 07:28 PM
TJSwear's Avatar
What did they do?
Old May 25, 2017 | 08:42 PM
LT80's Avatar
LT80 Expert
They make nests and their wastes cause problems.
With you having the belt off, this isn't your situation.
IMO you'll have to remove both front and rear clutch and inspect.
Front for bad rollers(doubtful) and make sure it slides on the spacer. Rear: squeeze the clutch face. It should slide. If all that is freely working, it's not the clutch.
Old May 30, 2017 | 11:35 AM
DirtDevil101's Avatar
Easiest way to know if clutches are working is to run it with rear wheels off the ground and clutch cover off...if clutch sheaves move with changes in RPM then all is good...if not...not so good...this is how us sledders validate full shift-out...
