96 Yamaha 250cc Timberwolf
Old Jun 19, 2017 | 08:48 AM
Deleye's Avatar
Default 96 Yamaha 250cc Timberwolf
Need help with carburetor issues. Motor is skipping also if fuel is left on is runs out overflow tube. Any idea's on what to do?
Old Jun 20, 2017 | 03:05 AM
The float needle is not sealing properly, it could just be dirt stuck between needle and seat, or it could be a worn needle, I guess it also could be the float height wrong or the float with a hole in it, but most likely dirt. Try turning fuel tap off and running out of fuel, then turn tap on again, this can flush the grit from the needle. If that doesn't work, you will have to take the float bowl off clean the needle and seat, and check the components for wear, float height etc. Blow the jets out with compressed air while you have the bowl off, to ensure everything is working properly.
Old Jun 20, 2017 | 10:12 AM
Deleye's Avatar
I will check. I know it is a new carburetor . I will see if it helps.
Thank you
