Arctic cat 90 will not start
I have an Arctic cat 90 that will not start. It won't turn over or make any kind of attempt to start. I have a new battery in it. My Grandson and I went for a ride stopped to get a soda when we tried to start it nothing happened.
I'd check for a blown fuse. Not sure where it'd be located but Polaris had a fuse holder under the seat. Plus most of the little ones have a starter lock out switch on the brake lever that allowed power to the starter relay when the lever is pulled. Check that the plunger is ok if so equipped.
What "old Polaris tech" said. My grandson has a 90 Kymco, same machine. About a year ago he started having minor trouble getting it to start. You would have to pull on the brake lever a few times and it will start right up. Age, dirt, corrosion, who knows. That would be my first guess. Did it start with the kick starter?
