96 explorer 300 gear case leak
I just got a 96 Polaris explorer 300 4x4. the gear case is leaking from between the two halves. is there a gasket between the two halves that can go bad and does anyone know where to get a shop service manual on how to fix it
No case gasket. Uses a sealant similar to Yamabond,Threebond. You might clean the case up,try to tighten the case bolts that you can reach along with the frame bracket bolt and nut that goes through the case. May help. Here's a service manual for 10 bucks that covers your model.https://www.tradebit.com/filedetail....l-polaris-atvs
Cederbergb
Apr 18, 2017 09:49 AM
