96 explorer 300 gear case leak
No case gasket. Uses a sealant similar to Yamabond,Threebond. You might clean the case up,try to tighten the case bolts that you can reach along with the frame bracket bolt and nut that goes through the case. May help. Here's a service manual for 10 bucks that covers your model.https://www.tradebit.com/filedetail....l-polaris-atvs
Cederbergb
04-18-2017 09:49 AM
