Unexplained acceleration. Ice?
Old Jul 10, 2017 | 05:13 PM
close call's Avatar
Default Unexplained acceleration. Ice?
I have an 02? Yamaha Grizly that on frosty mornings has continued accelerating three times. It only happens in the first 2 or 3 minutes of operation. Thankfully there is that nice red switch on the left bar. Each time i have opened it all up checking the free motion of all the components. I left the cover off the carb side to be able to see the butterfly position if it happend again. When it did, i killed it and watched the butterfly slowly return to idle. Could this bee ice forming under the slide and coming loose lodging in the butterfly?
Old Jul 18, 2017 | 09:39 PM
Oldbear's Avatar
Sounds like a bad deal. Beings it happens only on frosty mornings I think icing up probably is your problem. I guess I'd start with using gumout spray or similiar and clean all linkeage from thumb throttle all the way down. Then in the winter try some different gas and maybe put a little seafoam in it.
Malcolm Nye
Jan 20, 2021 06:55 PM
Ice Cube
Jun 8, 2017 07:47 AM
Tommyr1k
13
May 27, 2017 07:18 AM
momoboy
Mar 12, 2017 03:41 PM
hookster73
Jan 24, 2017 08:35 PM
