no power to the breaker in the bag
Old Jul 27, 2017 | 06:18 PM
46 cub's Avatar
Default no power to the breaker in the bag
2002 polaris 500 ho sportsman! after changing the starter, I hooked the battery back up and tried starting it, in that process the netural lite went out, no power to headlights nothing... Help, on the old battery tested bad at 9.4 volts I have a new battery. Still no power to either side of the circuit breaker...???
Old Jul 27, 2017 | 10:41 PM
No power to the circuit breaker can be a shorted fusible link.Branches off the solenoid on the wiring diagram.Check for power on each side of it.Cheapest oem I've found.POLARIS PURE OEM NOS ATV FUSE KIT LINK GREY 2461085 2202147 | eBay Or you can match the size at any auto supply if it turns out to be shorted.Plus left control switches can cause problems.Work the on/off switch back and forth and check that connectors are clean and tight.
IgorSvec
May 27, 2017 03:43 PM
Al-53
Feb 9, 2015 07:17 AM
Mr. Fancy Pants
May 30, 2011 02:02 PM
cscotter
Apr 12, 2009 06:08 AM
d33pt
May 5, 2003 10:23 AM
