carb adjustment
Old Aug 14, 2017 | 08:22 PM
joey1983's Avatar
Default carb adjustment
2005 honda trx90 adjustment on carb need to know how many turns out to set it at
Old Aug 14, 2017 | 10:07 PM
Kymco 450i's Avatar
Usually about 1 1/2 - 2 turns out to start with, then fine tune after warmed up with engine running. Typical for most engines
Old Aug 15, 2017 | 10:44 AM
DirtDevil101's Avatar
2.0 turns out from lightly seated is the general baseline for the a/f mixture screw as mentioned. To set it, get it warm, set idle fairly low, then turn in slowly until it stumbles, then out until it stumbles, then back in to where the idle sounds the smoothest...that will get you very close...
cornermike
Aug 28, 2016 12:23 PM
HomelessManatee
1) Engine problems..
Aug 5, 2016 10:13 AM
426Hemicuda1
Jul 29, 2016 10:35 PM
93-350l
Jul 17, 2016 04:15 AM
