steering
Old Sep 23, 2017 | 08:15 PM
sdoenges1955's Avatar
Default steering
steering quits after running 45 minutes. 2000 sportsman 335
Last edited by sdoenges1955; Sep 23, 2017 at 08:17 PM. Reason: was not specific on the model and year
Old Sep 24, 2017 | 05:55 AM
Could explain a little more in detail as to what it's doing.. Steering post,upper and lower bushings and tie rods.Simple system. If it's pulling or jerking from one side or another,problem could be in the hubs.
Old Sep 24, 2017 | 11:50 AM
user493's Avatar
Moto Psycho
I read this last night and still don't know how the steering could quit. I never heard of such a thing happening.
Old Sep 25, 2017 | 03:05 PM
the wheels turn left and right but it keeps going straight
Old Sep 25, 2017 | 04:44 PM
That makes even less sense than your first post.. The only thing off the top of my head is if a rear u-joint or joints on this older style drive shaft was bad. I've had them worn out to where it was hard to keep them tracking straight or the rear end would kick out some.
Old Sep 25, 2017 | 04:57 PM
user493's Avatar
Moto Psycho
The only time I ever heard of that happening was when my friend had bald tires. They didn't have any traction so when he turned the wheels it still went straight.
Old Sep 26, 2017 | 12:35 AM
I'M sorry for being confusing... just repeating what mt son in law said, I got it my garage now and will see if I can get it to malfunction.... thanks for helping and I'll det back to you!
Old Sep 26, 2017 | 05:03 AM
I got it jacked, put in neutral all wheels turn with a little resistance, except the right front it spins freely.....wasn't running.
Old Sep 26, 2017 | 05:48 AM
Crank it up while in the air and have the awd on. See if both front wheels turn and that you can't stop them by force.Hit the awd button again for two wheel drive. If one front wheel keeps turning and you can't stop it,then that may be what your son in law meant. Steering would pull to one side while driving.This would normally be a mechanical problem. Hub could be dry,armature plate magnetized keeping the hilliard engaged,etc.
Old Sep 26, 2017 | 07:06 PM
OK I did what you said, what I found was the right front wouldn't engage at all it free spins with no resistance, the left front stays engaged in 2 wheel and 4 wheel drive.might have more than 1 problem on my hands, never worked on a ATV but I worked on locomotives for 37 years. just have to adjust.
