steering
Old Sep 26, 2017 | 11:23 PM
sdoenges1955's Avatar
also noticed that the right front axle is loose ....like the axle nut backed off...probably why its not engaging, and if I unplug the wires to the coil for the (brown white gray white wires) will it nullify the awd 2wd button and just shift it manually?
Old Sep 27, 2017 | 03:25 AM
Disconnecting power to the hub coils doesn't guarantee that a mechanical problem won't still lock a hub in. You need this manual to acquaint yourself with the awd system,what to check for and repairing.Videos can help,but the manual goes further including strut seal sleeves,sleeve and inner pole gap,etc.2000 Polaris Sportsman 335 Service Manual PDF Download
Old Sep 27, 2017 | 03:29 AM
Thanks Old Polaris! you've been a great help!
Old Oct 9, 2017 | 03:55 PM
Default 2000 polaris 335
I tightened the axle nut on the right side, both axles were low on fluid, filled them to specs, front axles are always engaged in 2wd. can you help?
Old Oct 9, 2017 | 05:11 PM
  #15
Hubs being low on fluid can cause problems. If the front wheels are still engaged in 2 wheel drive,the most common cause for this was armature plates becoming magnetized. This causes the hilliard to lock into the hub full time. Item #4 on the parts break down. Cheap parts,about 10 bucks each,but need to be replaced along with checking for any bearing, hilliard damage or damage to the strut coil sleeve and inner pole where the armature plate rides. Several videos out there that can help,but again the manual shows you step by step.. Here's one on the Scrambler 500,but same system,same parts involved.
bortman
8
Sep 24, 2017 11:22 AM
murphman
Sep 19, 2017 07:54 PM
keithert
Sep 1, 2017 09:33 AM
joeldub1121
Aug 30, 2017 07:24 AM
Preachaman
Aug 29, 2017 04:27 PM
