finally finished my warrior!
Old Apr 19, 2001 | 03:03 PM
thejerm14's Avatar
hey guys i finished my warrior finally. i got a high performance white brothers cam, weisco piston, bored my cylinder 1mm, titanium valve springs, ported and polished head. i can now pull a wheelie in sixth gear. it's awsome.
Old Apr 19, 2001 | 04:05 PM
TexasDS's Avatar
Have you raced anybody yet?
Old Apr 20, 2001 | 02:54 PM
thejerm14's Avatar
yeah i raced a blaster, stock banshee, piped warrior, 310ex, stock 400 ex, piped and bored banshee. i beat them all except that piped banshee. and the 310 stayed close until we got to the higher gears then i started to pull away.
Old Apr 20, 2001 | 11:03 PM
fast98warrior's Avatar
great to hear about your warrior! I am thinking of putting a cam, air filter, and tires on mine. tires first though... tired of getting stuck! hehe
Old Apr 21, 2001 | 01:08 AM
krazee's Avatar
Hey i got a question for ya!
I bought a parkin brake block off installed it but after i took the parkin brake off the motor wont rev out it cuts out real bad. I know what the problem is. It is the switch on the clutch lever. Someone told me to unplug it. I unplugged it and it does the same thing. Do i have to disconnect it from the CDI or what? Thanks for the help man!
Great to hear about your Warrior!
Old Apr 22, 2001 | 03:21 AM
thejerm14's Avatar
i got a new lever and perch and then, then two sets of wires that i unplugged, and then i threw away the wires and old perch and plugged the left over wires into each other. hope this helps. good luck
Old Apr 23, 2001 | 12:44 AM
Joe1La's Avatar
I just bought the White Brother mild cam for my 98 warrior, I have A WB E-series pipe, k&n Filter and jetting, and a 12 tooth sprocket. What can I expect to feel from the cam. and how hard is it to put the cam and new spring in???
So how did the 400ex do in the race against you.
Thanks!!!
Old Apr 25, 2001 | 01:30 AM
thejerm14's Avatar
me and the 400 were about same off the line then i just pulled away. and to answer your cam question, the cam itself isn't hard to get in. make sure you get a new cam bearing, and stronger valve springs(white bros. makes titanium ones, thats what i used). you won't get the old springs off or the new ones on without the tool for them. other than that it's pretty easy.
Barnsnelbon
Sep 27, 2015 03:07 AM
kbazzy
Sep 26, 2015 11:26 AM
Bernhard
Sep 25, 2015 12:45 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
byronman
Sep 6, 2015 06:34 PM
