450 honda
Old Oct 16, 2017 | 11:26 AM
clintelmore's Avatar
Default 450 honda
engine will spin over but won't crank.has new carb,fuel line ,filter and plug?
Old Oct 16, 2017 | 01:15 PM
hydrex's Avatar
No different than a car, try jumping the starter with 12 volts, if it kicks in , then it's probably the ignition switch. Check the connection at the starter. Also check voltage at battery, ATV batteries are famous for crapping out.
Old Oct 17, 2017 | 02:53 AM
Find out if you have a spark by removing the plug, refitting the lead and laying it on the head. If you don't have a spark, unplug the voltage regulator. Don't know why but on the 450 only, a faulty regulator often cuts the spark.
Nov 23, 2016 10:05 AM
Nov 23, 2016 03:10 AM
alfred1976
Aug 26, 2016 11:21 AM
zdrucker
Aug 17, 2016 05:13 PM
lovinhonda
Jan 25, 2000 09:17 PM
