idling fast
Old Oct 18, 2017 | 12:04 PM
Michael Claggett's Avatar
Default idling fast
1995 Honda fourtrax 300 2x4 The carb. has been rebuilt, and now it idles fast but the adjustment screw is all the way out. ???
Old Oct 19, 2017 | 03:50 AM
Check the cable adjuster on the handlebar lever box. If the cable is tight, the lever on the carb doesn't touch the adjuster on the carb. Other possibilities are butterfly sticking or an air leak, or choke slightly open.
Old Oct 19, 2017 | 01:21 PM
thanks I will try that
Old Oct 19, 2017 | 02:33 PM
DirtDevil101's Avatar
Couple thoughts:
1) make sure the slide/needle jet is installed correctly and verify visually or by feel that your slide almost bottoms out with no throttle
2) make sure your intake boot is installed correctly & has no cracks - excess air can raise the idle...
Old Oct 20, 2017 | 03:18 AM
"1) make sure the slide/needle jet is installed correctly and verify visually or by feel that your slide almost bottoms out with no throttle"
Honda 300s have a butterfly throttle CD carb.
Old Oct 20, 2017 | 07:49 AM
Oh...well that makes it easier then...
But surprising at the same time...
Ajax
Mar 17, 2020 09:28 AM
clayh
Oct 9, 2016 01:13 PM
230e
Sep 23, 2016 01:03 PM
COFatboy
Aug 21, 2016 06:04 PM
