1986 LT250F Starting Issues
I have a 1986 Suzuki LT250F its getting spark just cleaned the carb (Need Carb Settings)
The Quad wont start by pull start unless warmed up electric start is messed up (Electrical issue) only way to start it is bump start any suggestions on how to fix.
May be worth checking compression, low compression (under 90psi) gives poor starting. However, trying to start a reluctant engine on the pull start is a waste of time and effort. Fix the electric start, then see if it fires up reasonably easily.
