Polaris predator issues
Old Jan 25, 2018 | 06:16 AM
Luv2shoot's Avatar
Default Polaris predator issues
Hello.. my son's Polaris predator 90 will start and idle great. As soon as you rev it it sounds like it has a rev limiter. I have checked everything basic and I am totally lost. A little direction would be appreciated
Old Jan 25, 2018 | 07:43 AM
Could be several reasons for this but start out with the carb and fuel supply. Make sure fuel is getting to the carb and that carb internals are clean.Main jet,pilot jet clean and open along with all openings blown out. Also clean the needle and seat,make sure it's not sticking.You don't say what year model,but if it's an older 2 stroke,check that you have good exhaust flow.These old pipes could easily get stopped up with oily carbon over the years.Flushing them out with kerosene could help. If you rule fuel,carb out as the problem,a worn drive belt,worn clutch parts can basically do the same thing and cause limiting.
Old Jan 25, 2018 | 08:08 AM
Luv2shoot's Avatar
I have done everything with the carb with no results. Clutch seems free and belt is good
Old Jan 25, 2018 | 08:09 AM
Luv2shoot's Avatar
It's a 2001
Old Jan 25, 2018 | 08:18 AM
Then I'd do a compression check. May have enough to crank and idle as some I've seen,but couldn't take throttle if compression is too low.If you want more info on this here's a manual that can help.Has fuel,mechanical and electrical tests.Scrambler90 ,Sportsman 90 all the same.2001 Polaris Scrambler 90 Service Manual PDF Download
Old Jan 25, 2018 | 08:20 AM
Luv2shoot's Avatar
I will try that. Thank you
Old Jan 27, 2018 | 02:39 PM
Luv2shoot's Avatar
Ok so I did a little more tinkering today and jumped a screw driver across the spark plug. It is definitely the spark pulsating if that makes sense. Where do I go from here. Stator is clean all wires are tight that I can tell
Old Jan 27, 2018 | 04:09 PM
Compression test just to rule it out as a problem. If it's within range,then I'd still check out fuel supply to the carb and recheck your cleaning work. Make sure the jets are clean,floats ok,not sticking. Air screw on these little ones are usually between 1 3/8 to 1.5 turns out. If you can rule that out,possible you could have an electrical break down and the manual can go through tests on that among other trouble shooting guides.
Johnny821
Oct 22, 2016 09:11 PM
Matt4atv
Jun 7, 2012 11:28 PM
kawasakifrrreak
Jun 9, 2008 02:50 PM
