2001 kodiak won't start
Old Feb 3, 2018 | 01:41 PM
wwrafter's Avatar
Default 2001 kodiak won't start
sounds like bad solenoid but replace and sounds the same, any help would be appreciated
Old Feb 3, 2018 | 02:43 PM
Is voltage going to the starter from the solenoid? If the solenoid just clicks,but has power to the starter,possible a starter is bad. If the starter is turning over,then could be a worn starter clutch not engaging.https://www.yamahapartshouse.com/oem...starter-clutch
Old Feb 3, 2018 | 05:03 PM
wwrafter's Avatar
Thank you for your reply and suggestions.
Turns out that my battery charger/emergency starter isn't working properly. I jump it from my tractor and it started immediately.
Thank you
wwrafter
Old Feb 4, 2018 | 12:14 AM
Check that the battery is receiving around 14 volts from the regulator at an idle or a little above.If it's charging ok,you may need to have the battery load tested if it's getting weak not holding a full charge.
Old Feb 5, 2018 | 01:36 PM
wwrafter's Avatar
Thanks again I will check
Spencer Warren
Feb 2, 2018 01:13 PM
Bobbyray
Jan 27, 2018 10:58 AM
bloodytrx90
Jan 18, 2018 08:05 AM
papaw718
Jan 17, 2018 05:18 PM
bosborne3562
Dec 7, 2017 03:44 PM
