CAN-AM (BRP) Ask an Expert! An area where experts in their field will answer Non-General or Non-Basic questions about your CAN-AM (BRP) ATV. ASK ALL GENERAL QUESTIONS OR BASIC QUESTIONS IN THE CAN-AM (BRP) SECTION. Basic or General questions posted in a expert section will be moved!
MrHorsepower and other experts will answer your questions as they have time.
01 bomedier not starting
Old Feb 18, 2018 | 09:43 AM
Whitetailhunter8955's Avatar
Default 01 bomedier not starting
Good morning,
I am working on my uncle's 2001 bomedier traxter st 500. The starter just spins. I put a new starter in and it just does the same thing. I am guessing it is maybe a sprag clutch or something. I am not familiar with these wheelers.
thank you for ur help
Old Feb 18, 2018 | 11:39 AM
Several different versions of the Traxter 500 but all seem to show a stater gear and idle gear. Teeth may be chewed up causing starter to spin. https://www.canampartshouse.com/oemp...ectric-starter
Old Feb 18, 2018 | 11:43 AM
When I had the starter out i could feel the gear that the starter spins and that one felt good. Is there any videos to watch on how to work on this problem? Could it be a sprag problem?
it is a XT
Old Feb 18, 2018 | 11:54 AM
Same thing on the XT shows a double starter gear and main gear. Teeth may be good where the starter engages,but the smaller gear could be sheared where it hits the flywheel gear. Doesn't show to have a one way sprag clutch.
Old Feb 18, 2018 | 03:46 PM
Have you ever changed one? How do I change it?
thanks
Old Feb 18, 2018 | 04:51 PM
Nope,I havent but you have to pull the cover to check things out. This can help a lot better than I can at 5 bucks.2001 Bombardier Traxter Service Manual PDF Download
wisconrincon
Jun 9, 2006 12:34 AM
SnowDrift
Jan 22, 2005 01:22 PM
Jerrod695
Jun 12, 2000 10:05 PM
