Raptor case saver
Old Apr 20, 2001 | 11:07 PM
671Raptor's Avatar
Does anyone Know of any after market companys that make a case saver for the raptor i keep throwing my chain. i have even had my cases replaced because they broke.The dealers have checked everything as far as the tension of the chain and the straightness of the axle carrier and it is good so they say.
Thanks for your help in advance
Old Apr 21, 2001 | 12:01 AM
GuyRaptor's Avatar
I'd be more concerned with why you keep throwing the chain? Is the proper tension on the chain, etc.?
Old Apr 21, 2001 | 10:21 PM
Madmike101's Avatar
Amen, raptorguy,
dude you have some serious problems if you are throwing your chain already. These machines have not been out that long to go through a chain.
just my 20 cents
Old Apr 21, 2001 | 10:47 PM
RaptorZone's Avatar
Your bearing carrier is probably misaligned inside the swingarm. It is actually pretty easy to do if you do not line it up with the marks on the arm correctly when you adjust it. A good way to check is to measure from the center of the axle to the center of the front hub on each side and compare numbers. Also, always use the adjustment bolts to move the housing back. If you just pull it back, it will get pulled forward on the sprocket side when you ride because the bolts are not seated against it. This is probably what is causing the chain to throw. Just my thoughts.
Old Aug 8, 2001 | 07:54 PM
NotuRaptor's Avatar
Check out the August issue of ATV Sport magazine on page 53. It is a 1/4" Billet Aluminum case saver for the Raptor. Sorry the price is not listed.
Tom Miller Motosports
3885 Hwy 22
Huntingdon, TN 38344
Phone (731) 986-0893
Fax (731) 986-5691
Old Aug 8, 2001 | 08:16 PM
Raptoryfn660r's Avatar
RIP Dear Friend
My chain has almost 36 hrs on it. Going by owners manuel with 1.6 inch of deflection mine still doesn't need adjusted.
EIF
Apr 20, 2017 07:15 PM
Troylee216
Sport Quads
Sep 28, 2015 09:34 AM
black_thunder
Sep 22, 2015 07:59 PM
WilliamBos
Sep 22, 2015 04:07 PM
