Boring or buying banshee cylinders???? please help!!!!!!!!!!!!!
ok, i have a big problem with my banshee and i don't know what to do. my left piston was in bad shape and the cylinder was barely scratched and needed a little boring to fix, but my right piston broke and scratched up the cylinder beyond repair. so i bought two new stock pistons and a right stock cylinder, that was a mistake! after i had the new parts i talked to the guy i got it from and he said that both cylinders were bored 20 over. so now i'm stuck with one new stock cylinder, one bored 20 over, and two new stock pistons. i've got two choices: 1) send the stock pistons back and get some that are 40 over and bore the cylinders to 40 or...... 2) buy a left stock cylinder. which would be the best way to go? please reply cuz i want to get this beadt running!
The cheaper of the two would be to send you pistons back and get .40th over ones and have the cylinder bored (if the scratches arent too deep)
Or you can dish out the cash for another new cylinder and use the stock pistons that you have.. This would be at least $50 more than the one above.. If not more.. But it'll be back to stock again... I guess its up to you...
TLC
07-11-2015 02:28 AM
07-07-2015 11:00 PM
