96 scrambler 4x4 400. Where I'm at now.
Old Feb 25, 2018 | 10:43 PM
Eyeballsdeep's Avatar
Default 96 scrambler 4x4 400. Where I'm at now.
Well I got the clutch off a couple days ago. Called the guy back who owns the machine and told him that the crank is smoked. The rod has play in it. Which is understandable since the inner crank bearing cage disappeared. The ball bearings are still accounted for but it looks like it (bearing cage)got ground up in the bearing and through scientifical magic it sublimationaly turned from a solid to a gas, and left the engine with minimal, if any, damage.this is what I found. Looks pretty bad but the bearing on the ballacer are fine. Although ill opt for a complete bearing set for this engine.
Draining out the shmoo.
Looks like the crank was rubbing against the case sides. Where could the bearing cage have gone? This thing was running when i brought it here. Although, i guess its possible someone through a top end together and passed the buck to the next guy.
The cylinder looks pretty good. A couple of light scratches, but it bloons out about .008 at the port webs so im going to send it out to get bored over .020.
There is very minimal play in the big end of the rod. When i hold the rod in one hand and tap down on it with the other it clicks. So this will get sent out aswell. New rod, rod bearing, and pin.
Old Feb 25, 2018 | 11:05 PM
The owner gave me the "go ahead", so ahead I go. Told him it wouldn't be cheap, but he wants it. I guess there's a price to pay for reliability and piece of mind, knowing you will will be able to get where your going, and also get back from where you've been.
Polaris....... The way out!
I'm going to be nice and winch the frame into my truck and pressure wash all the grime off this thing. It has been ridden hard and put away wet. I've already cleaned up the case halves. so why put a nice fresh engine in a dirt muddy machine. I used old crappy gas that has no use to run anything here, and an assortment of stiff brushes to clean the cases. It works good for cleaning grime and grease, but be weary of any ignition sources around, maybe a good idea to open up that garage door.
Old Feb 25, 2018 | 11:14 PM
I will add though, that everything else, aside from front shocks and the 4x4 works. The trany is fine all the other bearings and seals are good, throughout the drive line. I will be frugal with the pressure washer around the seals, as to not push dirt into the bearings and what-not, and also around the electrical. We don't want more problems.
Old Feb 26, 2018 | 09:23 AM
Brings back old memories.. The cylinder is where the bearing race probably ended up little by little over time. Glad you're rebuilding it right. I'd pull the counter balance and check the bearing behind it also.If it's bad there's a place on ebay that replaces them on your shaft or if you have a press you can replace it yourself. https://www.ebay.com/itm/polaris-cou...lRoB6C&vxp=mtr
Polaris5004x4
Apr 12, 2014 01:21 PM
SCRAMBLERMAN97
Jun 28, 2003 05:59 PM
hannah
Aug 21, 2002 02:10 AM
4man2k
Jul 4, 2000 02:40 AM
