battery indicator blinks on and off
Old Mar 5, 2018 | 09:12 AM
nytro1's Avatar
Default battery indicator blinks on and off
2013 sportsman 500 ho Replaced battery and charged - starts and runs but the battery indicator flashes and cant get the taillights to work bulbs are good any help would appreciated
Old Mar 5, 2018 | 11:19 AM
Battery indicator flashing is warning you that something is wrong with the battery,a connection issue or charging issue either from the regulator or possible stator short.Check all battery and ground connections first along with the regulator connections. Crank it up and check that you're charging 14-14.5 volts at the battery. If it's lower or just shows battery voltage most times it's a faulty regulator. You can eliminate a stator as the cause by checking resisitance between each yellow stator wire leading to the regulator. Should be a small amount of resistance between each wire with no wire shorting to ground.Also an ac output test can show if the stator is ok. This video shows how to test the stator.
If the stator checks out you can go oem on the regulator or take a chance on a cheaper after market regulator.4012192 is the oem part number.https://www.ebay.com/sch/4012192%20Polaris?rmvSB=true
cornermike
Aug 13, 2016 09:33 PM
steelhead loco
Aug 8, 2016 04:40 PM
steelhead loco
Utility ATVs
Aug 8, 2016 08:18 AM
bbm1019
Aug 5, 2016 09:32 AM
4wheelr220
Jun 27, 2000 12:30 PM
