2000 Honda recon
Old Mar 11, 2018 | 12:59 PM
Tony Bryan's Avatar
Default 2000 Honda recon
Purchased this 250 recon new and it has been a great ATV. Yesterday as I was using it around my place doing yard work it started having trouble ideling. After stopping for a minute I attempted to crank it up and it backfired and lost all compression. What could cause this?
Old Mar 12, 2018 | 02:53 AM
Let us hope it is just a valve stuck open, but there is a problem with the Recon, in that the cam chain tensioner can break, throwing valve timing out, the piston can then hit a valve, bending it. Take the rocker cover off and check if there is a lot of clearance on one valve. However, to check if the timing has slipped, the clutch cover has to come off, a broken tensioner would then be visible, as are the timing marks.
Old Mar 12, 2018 | 08:06 AM
Tony Bryan's Avatar
Default Thanks
I’ll probably get some one to work on it for me
Roughneck25
Apr 13, 2008 02:38 PM
blackturbo
Dec 3, 2006 11:54 PM
blackturbo
Nov 28, 2005 12:43 AM
t-roy
Jan 13, 2000 06:43 PM
