overcharge at idle
Old Mar 11, 2018 | 03:37 PM
anthony59's Avatar
Default overcharge at idle
sportsman overcharges one time then dosent charge enough the next time could this be stator problem
Old Mar 11, 2018 | 04:46 PM
Could be the stator or the regulator. What year and model.. Makes a difference.
Old Mar 12, 2018 | 07:21 AM
anthony59's Avatar
its a 2010 sportsman 500 ho
Old Mar 12, 2018 | 07:22 AM
anthony59's Avatar
I have replaced the regulator twice on it
Old Mar 12, 2018 | 10:15 AM
You can do a general stator test on the yellow wires leading to the regulator. Should be some small resistance between each wire with no yellow shorting to ground.If any yellow shorts,replace the stator. You can also do an ac test if the resistance test passes. Set the meter on ac volts and crank the engine up. Between each stator leg,Red meter lead on yellow 1 black lead to yellow 2 and yellow 3. Should show between 30-45 ac volts above 2000 rpm. If it shows less or nothing. Replace the stator
Old Mar 12, 2018 | 01:20 PM
anthony59's Avatar
it shows 45-47 ac but yellows show short to ground,does this make sense
Old Mar 12, 2018 | 01:50 PM
Weird,but after two regulators I think that's what you're down to. Some stators on ebay or amazon are as cheap as the regulator,but may be 50/50 on them as far as reliability goes. Oem,Ricks or Ricky Stators would be more reliable,but more bucks.
Honda Dave
Nov 12, 2017 09:04 AM
racingjoe66
Apr 2, 2017 09:04 AM
NewDS650
Dec 7, 2013 10:47 PM
ctdnwakulla
Feb 11, 2010 04:50 AM
oatman98
Nov 1, 2008 10:05 PM
