Starter Motor Problem
I have 90cc Chinese quad that I got like 5 years ago. when we got it, it didn't have a battery so we had to kick start it. It took 30 mins to start every time we went to ride it, then one day we just gave up because it took forever to start. Recently I have been trying to get running and I wanted to get electric start to have a better chance at starting. The idle gear and the gear on the starter motor were both rounded off so I bought new gear, starter motor and battery. I tried the starter motor before putting it in with jumper cables and it spun good, but when I put it in the quad and used the jumper cables it just tried to spin but couldn't. I have no idea what the problem could be. Any help would be greatly appreciated.
You can pull the spark plug and see if it spins over.Plus check all connections.You can recheck your work,but first try loosening the case bolts a tad and see if that helps.If it does then you know the shafts or gear are possibly in a bind when the case is tightened.
wifehatesit
Oct 1, 2007 07:29 PM
CHEWBACCA
Nov 14, 2003 05:15 PM
DuneMe
May 21, 2003 07:23 PM
