leaking fuel
Old Mar 25, 2018 | 12:28 PM
donelwell's Avatar
Question leaking fuel
Hello. I have a 2001 500 Auto AC, and is leaking gas, new fuel lines. dealer says there is no carb kit for it to replace whatever it takes to stop leak. Sounds kind of fishy. AC has 900 miles on it, adult ridden, ie not hot rodded or abused. Any ideas? thankyou in advance.
Old Mar 25, 2018 | 02:44 PM
Kymco 450i's Avatar
I would find out exactly where the leak is..if not repairable then a replacement will be needed.
Old Mar 25, 2018 | 03:24 PM
If it's carb related aftermarket carb kits are out there,but whether they're actually correct or not..https://www.ebay.com/itm/Quadboss-Ca...%7CModel%3A500 If it's just a worn needle causing problems and you want to go oem the auto and manual atv carbs shows to be the same and same needle valve and lists the bowl gasket,IF they're still available. https://www.arcticcatpartshouse.com/...0a1/carburetor
Old Mar 26, 2018 | 10:18 AM
donelwell's Avatar
Smile leaking gas
Thankyou sir. Hope it will be the right part. cant go 500 600 for new carb and labor.
Old Mar 26, 2018 | 11:18 AM
Kymco 450i's Avatar
Neither can the rest of us, that is why we learned to fix them ourselves. Repair places charge way to much and most do crappy work.
Murph660R
Dec 21, 2003 03:12 AM
Cleatus
Oct 22, 2002 12:09 PM
vdubn
Jul 26, 2002 07:58 PM
