99 Polaris 300 xpress
Old Mar 28, 2018 | 11:48 AM
Dustinm's Avatar
Default 99 Polaris 300 xpress
Any help would be nice I have a 99 300 Polaris Xpress supposed to be bored 20 over I was writing it about 3 weeks ago and it just died it's getting spark carburetors clean I have the top-end off now piston and rings are good moving accordingly don't know what else to do any help would be great
Old Mar 28, 2018 | 12:10 PM
Pleeez use a period every now and then so old guys like me can comprehend.. First off you should have checked compression in addition to checking for spark,fuel,etc. If you reassemble with the old head gasket doubt if you'll get a true reading,BUT do it. If it's lower than 90 psi then something's wrong with that 020 over top end. IF it has decent compression,a leaking or popped out crank seal(clutch side) can stop one dead in it's tracks.
Old Mar 28, 2018 | 03:05 PM
Dustinm's Avatar
I took the top end off an clend it really good an put it all back together an put the gas tank back on for a minute an tyred to start it an it shot out a flame
Old Mar 28, 2018 | 05:26 PM
You still haven't done a compression check. That's the heart of the engine.
Old Mar 29, 2018 | 03:40 PM
user493's Avatar
Moto Psycho
To make any kind of a fire you need fuel, air, and an ignition source, whether it's a campfire or any other kind of fire. An engine needs those same 3 things to run, plus compression. You're just not going to get ignition and a full burn without good compression.
dchurch
Sep 16, 2006 10:01 PM
texbob
Jul 24, 2005 12:04 AM
stevebuick23
Oct 13, 2004 07:38 PM
Dalliwacker
Nov 15, 2002 07:15 AM
