blaster front tires
Old Apr 21, 2001 | 01:18 PM
Blasted's Avatar
I have factory rear dunlops that are almost new but I need new fronts.I run back roads,mud roads,feilds bush rail line snowmobile trail etc. Should i buy stock fronts? I was looking at bandits too. Are these too aggresive for my backs?
1998 blaster
dg nerf bars
0.20 wisceo piston
Old Apr 22, 2001 | 12:38 AM
brokemybanshee's Avatar
get the bandits as soon as I save up the cash Im gonna buy a pair.. you shouldnt have any problems, mabe a little agressive traction but there's nothing wrong with that!!
Old Apr 22, 2001 | 02:35 AM
Rob4092's Avatar
I have a set of new Holeshots on my stock Banshee aluminum wheels that I don't use.
I would like to put them on my son's 99 Blaster.
Will they fit and bolt right on??
How will they look on it?
Are they much larger than the stock Blaster tires and wheels?
Will they make the Blaster more stable and less likely to tip?
Thanks!
Old Apr 22, 2001 | 12:26 PM
Yes they will bolt right on, banshee rear rims wont though.. the fronts are the same thing as the blaster except a little better quality. I had a pair on my old blaster, here is a picture
http://www.geocities.com/jibaridge/redblaster.jpg
They wont make it any more stable cuz they are basically the same thing, if you put wide tires on the rear that WILL make it alot more stable.. anyways good luck..
Old Apr 23, 2001 | 10:31 PM
Blasted's Avatar
brokenmybanshee
Did you see the article in blaster central about the bandits. this is the only thing that makes me nervous about buying the bandits.I do not want to have to shave them,do you think these will be too heavy up front with the stock rims? Is there any other tires you would recommend?
thanks: 98 blaster
dg nerfs
0.20 wisceo piston
Old Apr 23, 2001 | 10:50 PM
Daredevil1's Avatar
My razr's are great. Highly recommend them.
Old Apr 23, 2001 | 11:25 PM
I wouldnt worry much about the weight thing unless you are a hardcore racer or whatever.. the weight diffrence will be minimal, mabe 1-2lbs total.. As for recommending a tire its all up to you, it depends on your riding style and aera... if you are on hardpack or racing I'd recommend razrs/holeshots/bandits/whatever, in the mud blackwaters (of course ) mudsharks/bearclaws, in the sand paddle tires... its all about what you like...
P.s. when I removed my rear tires and rims and put the blackwaters on they were very close to the same weight, acutally the blackwaters might be a little lighter than the stock ones. (they are on .190's the stock were on steel)
Reactant
Mar 30, 2022 02:08 AM
Frisky2050
Apr 9, 2020 11:19 AM
JackTheKing
Jul 14, 2015 09:09 PM
joeyupton
Jul 14, 2015 11:51 AM
tporath
Jul 11, 2015 12:31 PM
