2018 Sportsman 2up question
Hola group,
just a quick question. I understand that the width of a 570 is approximately 48". Just enough to fit into the box of a pickup truck.
What is the width of the inner wheel to inner wheel? 35-40"? I'm just wondering if there's enough space to slide some loading ramp down between the tires, once the ATV is loaded onto a pickup truck.
TIA,
-Jav
TIA,
-Jav
My bad, I should be more clear. What is the space between the Sportsman 570 inner wheel well? just trying to determine if there's enough space to slide 2 ramps in between the wheel wells after I load the ATV into the bed.
TIA,
TIA,
Have to measure your ramps. Most ramps will easily fit under the atv that way. Most are much narrower than that per ramp, maybe 24" wide. I had a set of ramps I slid under my Brute Force 650 when I had my Silverado and its narrower than a new Sportsman 570. I think that's pretty much how everyone hauls their ramps. I use a trailer now but I still have that set of ramps, I use them to get my lawnmower in and out of my shed.
tonyt2778
Aug 22, 2019 04:48 PM
