Engine needs choking
Old Apr 26, 2018 | 03:58 PM
tractor man's Avatar
Default Engine needs choking
Will only start with full choke and idles good with full choke. Release the full choke just a very little and it dies!! Sorry, it is a 2001 Polaris 500 Sportsman.
Old Apr 26, 2018 | 10:30 PM
Powerranger262's Avatar
Bad gas?
Clean carb.
How long has it sat?
Miles?
Air filter
Fuel filter
Fuel lines
Clean carb
Clean carb
Clean carb.
Old Apr 26, 2018 | 11:58 PM
user493's Avatar
Moto Psycho
Originally Posted by Powerranger262
Bad gas?
Clean carb.
Miles?
Air filter
Fuel filter
Fuel lines
Clean carb
Clean carb
Clean carb.
Rebuild carb.
Old Apr 27, 2018 | 01:33 AM
Rebuild carb.
But rebuild it with a good quality kit. Plenty of rebuild kits out there that aren't oem quality,but this one is.https://www.ebay.com/itm/Polaris-Spo...9Wxi62&vxp=mtr Don't just pull a carb and try to clean one. You'd probably have to go back in and do it right anyway.
Old Apr 27, 2018 | 10:39 AM
Default engine needs choking
First off, Thank You for replying to my post for help. Second, I goofed and typed 2001, which is wrong, it is a 1999 500 Sportsman! Information on the ATV follows: Purchased new in 2001 after a dealer had some ATV's setting and tied up thru problems?? 0 miles on when purchased, at present has 287 miles on it, and would like to give to my son, but I would like to give him a good running machine. Setting in my garage, probably 7 years? Tank was nearly empty and I messed up by putting about a 1/2 gal in it, charging battery and attemped to start. After pulling choke all the way it fired right up, and idle OK until choke is taken off. Have no experience working on ATV, just JD tractor's and old pickups at home. I would appreciate all the info on how to take Carb off and will attempt to install new kit in Carb as suggested. Have figured out and removed side panels, seat, but lookin at the Carb, it looks complicated?? Thanks again.
Old Apr 27, 2018 | 12:52 PM
Several videos on these Mikuni cv carbs on youtube.This is on Magnum,but same carb if you have the 99 model Sportsman.
Plus the cheap 5 buck manual can help also.1999 Polaris Sportsman 500 RSE Service Manual PDF Download
Jdogger
Apr 26, 2018 08:16 PM
Landon9014
Apr 20, 2018 09:51 PM
Ryan Mann
Apr 16, 2018 02:23 PM
Ben Vinson
Mar 7, 2018 10:11 AM
musselmark
Feb 26, 2018 08:32 PM
