right rear wheel end clicks
Old May 1, 2018 | 09:00 PM
BIGBEAR4X4NUBE's Avatar
Default right rear wheel end clicks
1994 bigbear 4x4 right rear wheel clicks/snaping sound not consistent
with wheel rotation just somewhat intermittent....
Old May 8, 2018 | 03:17 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
you should post this in the Yamaha section. not sure if that has cv joints on back but if so then guessing a bad cv joint.
Old May 8, 2018 | 05:01 PM
Yeh I did a bad thing...I did repost in the Yamaha group...I had the wheels off as I am redoing the brakes,and while it was up with all 4 wheels off the grnd
I rotated the wheels back and forth and was no noise,but did not listen to the boot that covers the ujoints from the t/case to the diff will try that when I put it back up
to put the new brakes on.and mine is old and has the mono shock susp with the straight axle shaft.
thanks for the reply....
wdubb1
Jun 15, 2018 03:50 PM
FTSFTWNGU2
Apr 4, 2018 05:39 PM
Tattoomike
3) General Discussions..
Mar 17, 2018 10:11 AM
01Grizzly
Nov 18, 2000 01:58 PM
Tym
Jul 1, 2000 07:57 PM
