Kids Quads & Other ATV's - Ask an Expert! An area where experts in their field will answer non-general questions about your Chinese made ATV. mywifesquad, LT80, LynnEdwards and other experts will answer your questions as they have time.
90cc Koplin 2 stroke ATV
Old May 5, 2018 | 10:49 PM
Wakestudent's Avatar
Default 90cc Koplin 2 stroke ATV
My son was riding thru our trails last night and all of sudden the quad started bogging down at full throttle. We shut it off, then started back up fine / idle fine but when I push throttle under load it Boggs down and stalled. Checked for pinched lines and everything looks good. I lifted the back end up so the back tires where off the ground and seems rev up and tires were spinning ok. It’s just under load where it Boggs down and won’t move? What could be causing this all of sudden?
Old May 6, 2018 | 11:17 AM
LT80's Avatar
LT80 Expert
Welcome to the forums.
I'd start with a good carb cleaning.
Old May 6, 2018 | 11:33 AM
Woke up this morning and took the whole carb apart and cleaned all components, replaced spark plug, air filter and started it up fine. I took it down the street and after about 40-60 sec it started to do bog down again. Same issue as before. This has a auto choke, so I unplugged the choke and didn’t fix it? Why if I lift the tires off the ground it doesn’t bog down and runs fine? Hope you can help
Old May 6, 2018 | 02:05 PM
I cleaned the carb again, jets/ float etc.. lol problem fixed! Runs like a champ! Thank you LT80
Old May 6, 2018 | 07:24 PM
LT80's Avatar
LT80 Expert
Hope the kiddie has fun.
Old Dec 20, 2018 | 04:32 PM
Whiteboy223's Avatar
Default Kolpin 90 2 stroke
Hey lt80. I have a kolpin 90 and I was wondering the compression specs for the kolpin 90
Old Dec 20, 2018 | 05:36 PM
LT80's Avatar
LT80 Expert
Most motors need freshened if comp is below 90.
Old Dec 20, 2018 | 05:45 PM
Do you have any idea were I can find a new top end for the kolpin 90
Old Dec 21, 2018 | 09:51 AM
LT80's Avatar
LT80 Expert
I'm sure that ebay sells $30 junk kits or you can get a oem piston (.5 over) and have the oem cylinder bored to fit the piston. It's more expensive but much more dependable.
plower
Sep 27, 2020 07:10 PM
laubin
Dec 11, 2005 12:16 AM
Tanya
Sep 2, 2005 12:29 AM
