Honda rancher electric shift problem
Old May 21, 2018 | 06:07 PM
stephenwillis's Avatar
Default Honda rancher electric shift problem
I have a 2003 Honda rancher ES and for some reason it keeps blowing the electric shift fuse I have replaced five probably already within 20 minutes. If you have any idea what’s wrong please help me out thanks
Old May 22, 2018 | 02:23 AM
I think the ES fuse is connected directly to the shift motor, (could be wrong). So unplug the shift motor and try the shift buttons, if it still blows, it is a wiring or ECU fault. If it doesn't blow (it will fault code) take the motor to pieces and see if anything is wrong inside it. The motors are swine to get back together.
Old May 28, 2018 | 10:27 AM
The fuses actually supposed to be at 10 AM but if I put a 15 minute it don’t blow should I leave a 15 minute or what?
Old May 29, 2018 | 01:57 AM
Fuses are rated in amps not minutes, but there is something wrong if it blows the correct fuse. Are you sure it should be 10 amps, check what it says on the fuse box lid.
Old May 29, 2018 | 06:31 AM
It’s a 10 amp Not a minute , Sorry about that. Thanks for your help
Old May 30, 2018 | 12:47 AM
No it isn't. I thought there was something wrong, so checked a 350ES we have in. The ES fuse is the one marked Motor and is 30amp, so which fuse is actually blowing?
hondafl350
Mar 29, 2010 08:12 PM
ringo1
Sep 8, 2009 07:18 PM
MTYRANCHER
Sep 21, 2000 12:56 PM
