1991 bayou 220 electric start problem
Old Jun 12, 2018 | 12:32 PM
Dannyk's Avatar
Default 1991 bayou 220 electric start problem
Just purchased a 1991 bayou, in great condition. The previous owner told me that the only issue was the electric start.After researching on the internet I have found several possible fixes but I would like pinpoint the problem.I have removed the recoil starter which worked with no problem. After removing the generator cover I noticed that the gear behind the generator is loose, is this where my problem lies? The gear will only spin in one direction but the looseness sort of scares me. Please help any replies will be greatly appreciated.Thanks
Old Jun 13, 2018 | 01:57 AM
First off, what is the problem with the electric start, won't work at all, spins but doesn't spin the engine over, what?
Old Jun 13, 2018 | 04:35 AM
Dannyk's Avatar
The starter will just spin , does not engage the flywheel. Battery is new and fully charged, solenoid is good, all cables and connects are clean and tight. Could the one way starter clutch be bad?
Old Jun 14, 2018 | 02:43 AM
Yes, to be certain, now you have the cover off, press the start button. If the big gear behind the flywheel spins round, but the flywheel doesn't, the one way clutch isn't working.
Old Jun 14, 2018 | 08:06 AM
Dannyk's Avatar
Gear definitely not turning, will order parts today, should take 4-5 days to receive, will keep you posted on my results. Thank you for the quick response and help.
Old Jun 15, 2018 | 01:30 AM
If the gear isn't spinning when the starter motor is running, it isn't the one way clutch, but the starter drive itself that is faulty. Not sure on the 220, but the 300 has a gearbox inside the starter, and a chain drive to the flywheel gear.
Old Jun 15, 2018 | 05:04 AM
Dannyk's Avatar
Large gear does not spin, it appears to be driven by the idler gear.When the starter button is pushed the starter and the idler gear spin but nothing happens to the large gear behind the flywheel.
Old Jun 16, 2018 | 01:58 AM
Right so it is the gear teeth on either the big gear behind the flywheel, which you can see, or the idler gear teeth, or something is missing/broken, which keeps them lined up.
vjc2010
Jun 2, 2010 08:47 PM
lawless
Sep 18, 2009 01:28 AM
mrlolman
Jun 14, 2007 08:51 PM
BayouBoy2772
Apr 30, 2005 12:54 PM
DynoDonCreason
Apr 23, 2003 02:29 PM
