my sons 110 cc zebra
Old Jun 25, 2018 | 11:47 AM
tgeer15's Avatar
Default my sons 110 cc zebra
so I gave my son a zebra 110 cc and after a week it started dying while he was riding it, a few people said it sounds like the strater, but not sure and no one around is willing to work on it and I can't find parts. any ideas will be welcomed
Old Jun 26, 2018 | 02:20 AM
No idea what a strater is, but ignore all comments except from experts. Firstly, does it cut out and then not re-start until it cools, or just loose power? If it just looses power when you get the revs up, it is probably the carburettor. However change the plug, just in case it is that, make sure there is plenty of oil in it, check the fuel tank cap is letting air through, a sucking sound if you open the cap when the fault is on, indicates a blocked vent. If it continues to die, clean the carb out. If this is a "sealed for life" item, it may be best to find someone who will work on it. Most 110cc bikes use the Honda Cub clone engine. If it is a copy of the Honda, parts are easy to get, as it is so common.
Old Jun 27, 2018 | 09:24 AM
Zrock's Avatar
Super Quad Patrol
Starter or stator? exactly what is the machine dooing dying can mean a lot of different symptoms
tgeer15
Apr 30, 2017 10:09 AM
