2003 sportsman 500, no power
Old Jul 1, 2018 | 01:40 PM
K9kodi's Avatar
Default 2003 sportsman 500, no power
Okay so picked up a 2003 sportsman 500 ho. It ran beautifully pull started but the starter relay was shot. I tried to take it apart and clean it and re install. I arc’d the battery trrribly working my big mits under the fender plastic. Anyhow, nothing worked after reinstall. I bought a polaris starter relay and re wired it in. Even made new holes in battery box for good ground. Now.......nothing. No lights, no winch, no awd, nothing on gauge cluster, nothing from key ignition. Now, if I turn bike to run and put key in start position I can pull start the bike, if I turn key to off position or flip the kill switch it will cut off. Where do I start?
Old Jul 3, 2018 | 07:37 PM
850 trailrider's Avatar
check your fuseable link wire coming off starter solenoid think it grey might of melted "doing its job"lol
Old Jul 3, 2018 | 09:09 PM
K9kodi's Avatar
I appreciate your help, really I do. I’m so frustrated I’m about to burn the damn bike. I have a replacement solenoid from polaris dealer. It’s diff looking then factory: it has two terminal ends and one stud for what I assume is the red white wire. I had an extra black wire that went to the old solenoid that I grounded. I know I’m missing something. I cannot find a fusible link anywhere
Old Jul 3, 2018 | 09:21 PM
K9kodi's Avatar
Which wire does that fusible link off the starter attach to? All black? I’ve only got one stud on the solenoid, I’ve got one wire running off solenoid. I hooked that to the red white wire. I’m missing something
Old Jul 3, 2018 | 09:50 PM
K9kodi's Avatar
So I have 12.28 volts at battery. I have 12.28 volts where it connects to the winch block on back of bike. Each one of the lines coming off the block, the ground and the two going forward read nothing. Does that matter?
Old Jul 4, 2018 | 06:03 PM
K9kodi's Avatar
So, I sat outside running resistance on all of the wires that appeared to have some importance. I have the white with red stripe wire hooked to the accessory stud on the solenoid and grounded the second wire that went to the previous starter relay like I thought the videos showed. I then traced that red wire to the front of the bike where it appeared to go into some control box. I figured it can’t be grounded it needs power. So I ran it to one of the posts on the solenoid and wouldn’t you know, gauge light up, bike turned over like a dream, everything works. Thank god.
Old Jul 4, 2018 | 07:00 PM
Glad YOU figured it out and got it fired up !Nothing worse than new parts that don't match up. Glad you didn't light it on fire in frustration LOL.
Old Jul 4, 2018 | 08:02 PM
K9kodi's Avatar
Oh it was close
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Jackg17
Sep 26, 2015 09:30 PM
Armymutt
Mar 13, 2015 02:29 PM
JHEdmonton
Aug 22, 2007 02:04 PM
csarver
Jul 31, 2007 09:39 PM
