E-Ton Viper 90 build
Old Jul 4, 2018 | 05:11 AM
stussy1's Avatar
Default E-Ton Viper 90 build
Hi All
Im working on my daughters E-Ton Viper 90, not the R model. It hasn't run in over 7 years as it sat at my in-laws house the entire time. What I did so far was break it down completely e.g. removed all plastics, took off carb, drained all old fluids and replaced, cleaned carb. Chain looks like its in good condition, just some surface rust and dirt, and it still moves freely. Definitely needs a new battery. I haven't done anything engine wise besides draining fluids. Will be replacing stock filter with a HP cone filter,
Is there anything else I should do to better my chances of a good startup and run?
Old Jul 4, 2018 | 01:19 PM
LT80's Avatar
LT80 Expert
Might as well blow a cpl bucks on a new plug. lol
I'm presuming the cone filter is a K&N style. I'd stick with foam.
Stick a lil 2 stroke oil in the gas tank till you run it enough to make sure the auto oiler works.
Maintenance the clutch's!
Welcome to the forums.
Old Jul 25, 2018 | 12:31 PM
stussy1's Avatar
do you happen to have a fuel and oil tank hose routing diagram? or pictures of an example? I made the rookie move of not taking pictures before hand and I just want to make sure I hook it up properly.
wcrook1007
Oct 24, 2005 03:22 PM
mxmike
Dec 20, 2003 04:59 AM
treeguy
Jan 7, 2003 06:18 PM
ezride
Jan 1, 2003 05:25 PM
395r
Dec 24, 2002 02:41 PM
