2012 Honda 250x lighting question
Old Jul 8, 2018 | 08:17 PM
tecate1987's Avatar
Default 2012 Honda 250x lighting question
Needing a headlight bulb for 2012 Honda 250x, I found oem and they cost like $40 for just bulb. Are there others that fit even with mod?
Old Jul 9, 2018 | 01:32 AM
I suspect the two headlights on the Honda 500fm of about 2012 will use the same bulb fittings although the bulbs are slightly lower in wattage (30/30w). Even they are $20 each. May be worth checking with your local Honda dealer, the same part, when used on a different model, gets a different part number and price.
Old Jul 9, 2018 | 06:02 PM
tecate1987's Avatar
thx, I looked at housing, the 250x is straight housing, compared to 90degree on the 500fm
may sill get it to work, do you know know how many leads are inside for plug?
Old Jul 10, 2018 | 01:35 AM
Take a look at the 350FM then, I think that may have the straight connection. All have three wires (main, dipped, and earth) except for the central light on the 500, which may have two wires (not sure).
wmtitan024
Jun 17, 2008 12:09 AM
frazw
Jun 28, 2007 03:21 PM
Thrashed250X
Aug 18, 2004 06:07 PM
Rob4092
Mar 12, 2002 11:42 AM
Rydogg
Mar 10, 2002 11:11 AM
