quad died while riding
Old Aug 15, 2018 | 11:02 PM
Wmrsanders's Avatar
Default quad died while riding
died while accelerating , friend took it apart for him and lost and damaged parts. the cam timing was off so I reset that but it didn't help . I set the cams up at first then down then checked the woodruff key, it was fine . The fuel pump was bad so I replaced that , it is getting fire , enough to jump halfway up my spark tester. Removed the injector it sprays but not a fine mist . Checked the fuses they are fine , disconnected most of the connectors and used di electric grease . And the valves seem ok when I put air in the plug hole the piston went down and no leaks , I don't have a small compression fitting for this plug. Does anyone have any advise
Old Aug 17, 2018 | 02:55 AM
What model? I had a 700 that had seized a cam. Because the gears are a press fit on the cams, timing marks on cam gears and flywheel were right but one cam was way off as it had moved in the gear.
atom0s
Jul 21, 2016 11:44 AM
spooge
Jan 7, 2001 07:12 PM
DIESEL4x4
Nov 22, 2000 12:04 AM
fast400
Sep 4, 2000 10:54 PM
