Suzuki King Quad stuck in gear
I have a late 90s King quad that is stuck in gear and will not roll. I am new to atvs and really dont know what I am doing so any help would be great! I bought it not running but it rolled but once I got it home it will not roll. Any ideas?
The main problem with 90s Suzukis is those stretchy cables they used for every control lever, check they are not jammed or stretched, so the levers on the gearbox don't operate properly.
Thanks for the reply! I tried that and nothing changed. I will add that it does not shift into 4wd and it also randomly does not go into reverse or hi/low/ super low. I pulled the right side cover and I can see where its not turning the gear all the way. Do I need to open up the main transmission?
So I checked everything and I dont see anything. I was just going to try to get it running and see what happened. It was died so I got a new Battery charged it up and I have nothing no click no lights nothing. Any ideas? Battery has good connections.
Are you certain you connected the battery the right way round, negative to earth? Check that the main fuse is OK. Check that the earth leads to engine and frame are tight. Check if the wire from fuse to ignition switch has power at the switch.
