Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
Rancher 420 won't start, solenoid just clicks
Old Oct 30, 2018 | 10:42 AM
Jmartinroe's Avatar
Default Rancher 420 won't start, solenoid just clicks
Hi,
I bought a used Honda Rancher 4X4 420 2013 ES this summer. I ran it a few time around the yard and all worked fine. It has about 905 miles and 203 hours on it.
I final got a chance to ride it in Mid October. Rode fine until the 4th ride. After about 200 yards it just stopped. The Engine and Temp light came on, engine died. I turned it off and then back on, shifted into N and the engine started. About 2 minutes later it died again. Now the only thing that happens is that the Solenoid just clicks.
I bought a new battery since it had a used one. That made no difference.
Volts 12.5V
Under Load with the solenoid clicking Volts 6V
Display: Has a N for Neutral and after I try to start it and the solenoid clicks the Gear Display shows a -.
Turn the key on and off and it shows N again.
The gears will change but stop at 3rd gear, won't go higher but goes back down to N.
I thought my next step would be to remove the PCM/EMC and test it as the Shop Manual says.
Any better ideas?
Thank you for any help.
Old Nov 19, 2018 | 09:13 AM
Cameron Paradise's Avatar
While not the same brand I had the same sort of problem with mine. Make sure the batter has a good charge then tap on the starter with a hammer. If there is more than just a click when you try to start it after tapping it, then you got a bad starter and it needs to be replaced and that did the trick for mine.
Old Nov 19, 2018 | 05:01 PM
Jmartinroe's Avatar
Thanks, I hope to try that on Thanksgiving Day.
My problem is why would the engine quite with a bad starter? It started 3 or 4 more times but would only run for a few seconds to a minute.
Old Nov 19, 2018 | 05:16 PM
I would also try cleaning the carburetor out there may be something clogging your jets
Old Nov 19, 2018 | 05:20 PM
And if all that fails check all your sensors and make sure the fan is turning but I check the starter first to get you started😂
cabb
Sep 9, 2008 05:10 PM
snipes4001
Jul 30, 2008 01:15 PM
MuscleQuad
Apr 23, 2007 02:34 PM
proudtobeon660
Apr 9, 2006 08:39 AM
