Atv starts but dies
Old Nov 16, 2018 | 09:46 AM
eimantas's Avatar
Default Atv starts but dies
Hello everyone i i have a chinese atv, there is spark, there is compression, ive changed the carburetor to nerw one recently and it starts and just dies, my starter motor gets hot, help me please i dont know what to do.
Old Nov 17, 2018 | 03:02 PM
eimantas's Avatar
Hello everyone so i just waned to tell that it doesn't die if you keep pressing the throttle button, but it just wont idle. Any ideas?
Old Nov 18, 2018 | 02:37 AM
Your new carb will need setting up, idle mixture screw and/or throttle stop screw will need adjusting to suit your engine. I would give the carb a clean first, in case something has got in the jets during assembly or transport. Then, if it idles when you hold the throttle slightly open, adjust the throttle stop screw up until this is as low as the throttle goes. If it dies when you try to get down to a circa 1000rpm idle on the throttle, you will have to adjust the mixture screw.
amman1972
Jul 19, 2013 08:58 PM
landintheusa
Technical and How-To Articles
Aug 6, 2008 12:40 PM
zenasskickin
ATC 3-Wheelers
Oct 23, 2003 12:28 AM
