Exhaust Painting - 400HO/500HO?
Old Dec 30, 2018 | 03:20 PM
WilliamBos's Avatar
Default Exhaust Painting - 400HO/500HO?
Looking to paint the exhaust on my 400HO next spring - has anyone done this to their 400/500? What I want to know is will those heat shield bolts snap? Thinking I may try to sand that part of the pipe between shield and shoot paint down between the shield.
if I get the atv good and hot, wonder if the bolts will bavk out without snapping?
Old Jan 1, 2019 | 07:29 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
I sanded mine down real good and used a baroque black paint so it would hold better. I would guess you would need a good torch set(with oxygen) to get the bolts hot enough to take the shield off. you might try PB blaster spray on them and let them set after a few different spraying to eat the rust if you don't have tanks to heat it up.
Old Jan 1, 2019 | 10:04 AM
WilliamBos's Avatar
A friend said run it till its good and hot, thrn a proane torch and they will come out.
im going to run VHT engine on the pipe, VHT ceramic exhaust and hit it all with VHT clear.
Old Jan 4, 2019 | 02:29 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
you can try the propane torch, but I would be surprised if it comes out with out using an acetylene/oxygen torch, but good luck.
WilliamBos
Nov 20, 2018 03:56 AM
WilliamBos
Jul 20, 2016 08:50 AM
pro94lt
Sep 24, 2011 09:48 AM
schmidt64
May 9, 2008 07:12 PM
Norseman
Jan 23, 2003 10:59 PM
