Olia Lloyd
Old Jan 17, 2019 | 02:57 PM
olia's Avatar
Default Olia Lloyd
I have a 97 TRX400FW and It's been a good bike, up until know. Started making a rattling noise in the front end and notice it wasn't pulling at the front wheels. Please help, not sure what it could be.
Old Jan 17, 2019 | 04:54 PM
Jered651's Avatar
either u joints in drive shaft, cv joints in axles or front dif gear is stripped.
Old Jan 17, 2019 | 07:08 PM
olia's Avatar
Default olia
Thanks Jered51, I'm going to to it down and inspect.
Old Jan 18, 2019 | 03:05 AM
Far more likely to be the front prop shaft splines gone. Lift the back end off the ground, engine off, in neutral, and spin a back wheel by hand, it shouldn't turn, as the front wheels should stop it, if it does, remove the cover from the front prop shaft and check how much of it is turning. If it all seems to be turning, it could be the spline into the diff, or the diff itself. If you can see a driveshaft inner CV turning, it is going to be that shaft splines or CV joint gone, never known that happen.
Old Jan 18, 2019 | 05:45 AM
olia's Avatar
Thanks for info. I'll let you know the outcome.
olia
Jan 17, 2019 02:53 PM
