2000 Polaris sportsman 500 4x4 issues
Old Feb 25, 2019 | 06:51 PM
Anthony1985's Avatar
Default 2000 Polaris sportsman 500 4x4 issues
Hi, I’m new here and new to Polaris quads, I have a 2000 Polaris sportsman 500, the 4x4 works fine in reverse when I push the override switch, but in the forward gears the 4x4 don’t work, any help would be greatly appreciated
Old Feb 27, 2019 | 11:40 AM
slowburn's Avatar
In both High and low range? Does the 4x4 indicator lamp glow? Check the voltage at the AWD hub coil connector for both hubs GRY and BRN/W wires. Should be close to battery voltage. If 12 VDC, then may be mechanical. I assume hub coils are ok since AWD in reverse, but you can confirm by measuring the resistance of each coil. Should be around 24 ohms each.. If no 12 VDC, I would check the trans switches. 2000 Polaris Sportsman 500 has two trans switches a front and rear and they both supply current to the AWD system based on the gear the machine is in.
Old Feb 28, 2019 | 02:42 PM
thanks for the feed back, will definitely check the hubs and the switches, also have to check a few more issues with it, won’t run without choke on, backfiring, sputtering, low power, bogging out, speedo don’t work, think I bought a lemon
adamrhymer101
May 10, 2021 12:54 PM
Mattburrill17
Feb 27, 2017 01:27 AM
Mattburrill17
Feb 26, 2017 05:20 PM
tonyvats
Dec 15, 2009 02:29 PM
Chawness
Jul 29, 2008 10:09 AM
