2001 polaris trail boss won't start I've put in a new carb all new fuel lines$$stilln
Hi im new here I boat a 2001 trail boss 325 from a guy that said nothing was wrong with it he had it runing wen I got there to pic it up sounded good he shut it off turned it on thought cool gave him 1250$ and loaded it got home won't start changed all fuel lines new carb cleaned tank checked fuel pump no start
Welcome to the forums.
So it cranks and won't start, or no crank. First thing I'd check would be the ground to be sure it's got a good clean connection.
If I read your post right and you put on a new carb, you may have added a whole new set of problems (unless it is identical down to the jets, needle circle position, etc.).
When trouble shooting it's best to do one thing at a time.
If it was running, the old carb probably isn't too far off. You might want to clean it up (paying particular attention to the pilot jet), blow out all orifices and make sure the choke moves easily.
On the other hand, it's easier at the moment to take Scootergptx's advice and check for a bad ground or a bad kill switch. I assume you checked for a spark?
It has a new carb on it all new fuel lines new spark plug going to check if the new plug has good spark wen I get off just put it in last night
Ok well ground is good plug has spark still won't start sprayed little starter fluid in air box it fired but killed out rite away and my battery keeps dieing could a bad batterie make it not start but turn over and even with my jumper it won't start
