147FMD carb
I have a some year Alta Mach 1. The engine is a 147FMD and the carb probably needs cleaned. Where can I get parts for it, or get a whole new carb? Its been in storage for about 10 years and the thumb throttle was stuck inside the carb. I got it loosened up but it still wont start. If I spary carb cleaning in the intake it will run for a few seconds while burning the carb cleaner, but its acting like its not getting any gas. I haven't taken the carb off yet to take it apart but I'm assuming the float is gummed up not letting the bowl fill with gas.
Well the engine is a copy of a Honda 70cc one so I would guess the carb will be too. I would take it apart, clean it out with compressed air put it back together and try it. I don't go in for removing needles, you have to re-set them afterwards if you do, and 99% of the time a blow out with an air line does the trick. there are plenty of videos of how to strip the Honda 70 carb if you need help.
fourlix
Jan 29, 2001 05:52 PM
