Noob Help: Belt Slipping?
Old May 29, 2019 | 08:02 PM
Proteus05's Avatar
Question Noob Help: Belt Slipping?
Hi Everyone,
Apologies for the naive question but I'm doing the best I can to figure out 2013 Sportsman 400 HO problem with little mechanical experience on a reserve in Northern Alberta, haha.
Last week a friend of mine broke down so I had to tow him and me and passenger home in mud. By the time I got home My quad was not throttling properly and seemed to chug with the passenger.
When I rode my machine by myself it seemed fine and "back to normal" but when I took passenger again it seemed to loose acceleration and not have much power and then really seemed to chug going up hills or loose terrain.
Based on google/forums I suspect I burnt out my belt when I towed so I replaced my belt today.
I've read you need to break a new belt in so went 20km today driving slow (20-40km/hr). However, I did notice that when I tried to go faster it seemed my old problem is back (no acceleration/loss of power over 1/2 throttle).
Question: Is this simply my new belt breaking in and normal? Or do I have a bigger problem here?
Appreciate any help as again I have very little knowledge about this sort of thing and am once again depending on the pros of this forum!
Thank you so much!
Old May 29, 2019 | 08:34 PM
Kymco 450i's Avatar
When ever a belt is replaced the clutches need a thorough cleaning as well. If the belt came apart then debris pieces could be trapped, not allowing the clutches to function properly. Clutch faces become glazed and that needs to be cleaned off. Lots of youtube info if needed.
Old Jun 3, 2019 | 03:48 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
a new belt would not make the issue you are describing. as mentioned the belt dust should be cleaned out. if you burnt your belt it would be severely glazed and should noticed it easily. hopefully you replaced it with an oem belt and not aftermarket. you might have also melted the buttons in the secondary clutch which will not let the secondary shift out correctly. this happened when you really overheat your clutches and belt like you did by doing what you did.
Old Jun 4, 2019 | 11:30 PM
Big Frank's Avatar
THE BERMINATOR
Veteran: Army
5 Year Member
If you were towing your friend in high gear instead of low, that's how you messed it up. That makes everything overheat and you should never do it. I think stendori is right.
HomeLoanPro
Mar 19, 2007 06:18 PM
gregpro50
Sep 9, 2005 11:25 PM
shooter29
Oct 20, 2004 06:25 PM
TeamGrnMojave269
Aug 7, 2004 12:16 AM
coolinthewoods
Jun 14, 2002 02:00 AM
