Has comp/spark/fuel no start
Old Jun 1, 2019 | 10:02 PM
Eilrahc83's Avatar
Default Has comp/spark/fuel no start
Can’t figure out why this bike won’t fire. It’s a Loncin 125cc motor, don’t know what the quad actually is cause the name plate is gone. It has good spark, compression and fuel but will not fire. Timing is right and valves are within tolerance also. Only thing I can think of is something electronic or a sensor is telling it not to fire? The bike used to run and ran well.
Any help would be appreciated guys, I’m at a loss here.
Old Jun 2, 2019 | 02:29 AM
If it has a spark, good compression and the timing is right, the only thing left is fuel. It has to be the right air/fuel ratio. Fit a new plug "just in case" then give the carb a good clean out and try again.
Old Jun 2, 2019 | 04:58 PM
Eilrahc83's Avatar
Ok I will give it a go tomorrow. I’ll grab a new plug. I read online that most of these Chinese quads like 2 full turns out from full seat on the a/f screw, is that right?
Old Jun 3, 2019 | 02:28 AM
Don't alter air fuel screws unless you have to. I just blow the passageways and jets out with compressed air. This works 99% of the time.
Just My Luck!!!
1) Engine problems..
13
Jan 29, 2017 02:34 AM
ostendorfg
Nov 17, 2011 09:29 PM
eiger0607
Nov 18, 2010 08:41 AM
01 406ex
Sep 8, 2009 09:43 PM
