'99 Warrior valve adjustment
Old Apr 25, 2001 | 12:46 AM
Electric350's Avatar
I am attempting to adjust the valves myself . The problem I am having is that when the camshaft sprocket is aligned with the head,the ''T''or TDC mark is not aligned with the crankcase index mark.
If I turn the crankshift a 1/4'' counter-clockwise then the ''T'' lines up and the camshaft sprocket is out of alignment with the head. I have already set the valves with just the camshaft sprocket aligned with the head. And the motor sounds normal. Though according to the repair manual all three marks should be aligned when adjusting the valves. Do all of these marks need to be aligned or is this normal?
'99 Warrior
'01 Rubicon
Old Apr 25, 2001 | 12:35 PM
thejerm14's Avatar
you need to pull off the cam sprocket and get it lined up, then adjust the valves at top dead center. hope this helps
Old Apr 25, 2001 | 10:05 PM
Sounds easy enough, I will give this a try.Thanks for your help.
'99 Warrior
'01 Rubicon
Reactant
Mar 30, 2022 02:08 AM
donintennessee
Jan 8, 2021 12:40 PM
STLyamwar
Jul 25, 2020 04:44 AM
Hankey Pankey
May 1, 2018 01:33 PM
suzukiquadrunner1987
Aug 6, 2015 05:29 PM
