Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
05 Sportsman 400 clutch
Old Aug 17, 2019 | 01:18 PM
larrypac's Avatar
Default 05 Sportsman 400 clutch
I have an 04 Sportsman 400, though I believe it is a 2004.5 so maybe different than some 04's. It is shifting quite hard and I have read many threads about this on Sportsman models but still unclear about some things. There is a surface at the bottom of the drive pulley that is about 1-1/4" in diameter, a wider space than the belt when idling (about 1250 RPM) and shiny and some threads have mentioned this being a bearing but it does not turn independently of the pulley halves and the parts blow up that i looked at did not show any bearing there. There seems to be plenty of slack in the belt when idling but the rear pulley is still turning. The belt was worn and I have ordered a new one but it would seem to me that a worn belt would create more slack and lessen the chance of engaging the rear pulley and would cause clutch slippage instead of making it engage at a low idle. Also, the owners manual mentions cleaning and lubricating the clutches but does not say what lube to use. Any advice would be appreciated. Larry
Ckieffer29
12
Feb 16, 2016 05:03 AM
S10V84Speed
36
Aug 7, 2014 05:57 PM
Twin LT80's
Sep 27, 2010 11:47 AM
Whitewater
Sep 6, 2006 07:55 AM
Marko
Oct 22, 2003 09:55 AM
